saveyourtime
I am finally bored by the noise from my emachine 500ix bought 2 years ago. I replaced the cpu fan/HS link, but it was still very noise. I realized that it is the hard drive that makes the noise, and I tested my thought by unplugging the cpu/fan 3 pin wire. First I thought my computer would have soon gone black. But it didn't. Then I ran a calculation task for at least 2 hours without any problem. So I was surprised, and I intended to ran it for longer. This time, it was about 4 hours until there was a sound from the motherboard and the computer freezed. Please note that during the test, only cpu and memory were used and the cpu usage was 100%. So I think for normal use, the cpu should be completely OK. I will test it later and let you know.
The other problem is that the power supply fan also make a little noise and my power supply is only 120W. I wonder is it possible that I can get rid of the ps fan? It seems that I need to cut the red/black wires. Has anyone had this experience?
I will buy a SilentDrive Link to minimize the harddrive noise. Anyone who has used it, please let me know how it is. Thanks!
Running without any fan!
