I got my car scanned at autozone, and it came up with a fault code of P0442 which could be caused by:
1) Faulty canister vent solenoid
2) Faulty canister purge solenoid
3) Faulty fuel cap (already took it off, then tightened it properly, CEL remained)
4) EVAP system hose malfunction
Do any of those (other than the fuel cap) seem like expensive repairs? On a tight budget, so looking to spend as little as possible. I'll probably take it to the mechanic tomorrow, but wanted to see what the wise minds at AT had to say. The car has ~71,600 miles on it.
