Cel II voltage and pin taping
Wulf
Have a mobo with no voltage adjustments, Is it possible to cut or paint some pins to adjust the voltage?
Killrose
6,230
8
Yes, go check out the archives at hardocp. There is an article there on this. Tough it only bumps the default up .10volt or so. I used the rear window defogger trick to do this and it works like a champ and is so easy.
V
Banned
Apr 2, 2001
1,821
Here ya go
I did this trick before on my BX133-RAID. I used a small wire I got from a flashlight. Good luck!
Killrose
6,230
8
Opps, rear window defogger repair kit trick. Conductive paint used to repair the broken lines on a rear window defogger. Same thing you would use to un-lock a T-bird/Duron. I've used it many times on Celeron II's and it takes less than two minutes, and by the time you re-assemble everything, it's dried enough to use.
