- Aug 22, 2004
- 13,140
- 138
- 106
My truck is throwing some codes. I've got a p0455 (EVAP large leak) and P0457 (gas cap loose/off). I can also way overfill my tank - the gas pumps will not shut off. I put 23 gallons in my 26 gallon tank with 1/4 tank left... smelled gas for days. D: But, I went over 430 miles on a tank :awe:
Anyway, I need to get this fixed. I'm trying to find the exact cause for this so I know what needs to be replaced. I'm thinking the evap canister purge flow solenoid is malfunctioning and causing the valve to be stuck open. That would explain the gas pump not shutting off, right?
Other ideas?
Other ideas?
 Facebook
Facebook Twitter
Twitter
