- Jul 26, 2002
- 11,757
- 0
- 71
The remote control to my ceiling fan is not working very well anymore. The fan will change speeds, but the light isn't responding but 10% of the time. I went to lowes and bought a new remote kit. The kit is made by the same manufacturer as the ceiling fan, Harbor Breeze. I figured I could just replace the remote, reprogram the remote to the receiver already in the fan and everything should work. I haven't had any luck though. Does anyone know if this should work, or will I have to reinstall the new receiver too? I'm hoping I don't have to because that will be a pain in he ass.
Unfortunately, all tech support for both fan and remote are closed and I can't find an instruction manual for the fan anywhere, nor do I even know the specific model of fan.
One last question, prob. a newb question... In the instructions for the new remote kit it says that this remote can't be used with a solid state speed control device... what exactly is that?
