tell me what output to print and i'll gladly do it
edit:
doing a bit of googling, seems i forgot to edit my fonts (didn't fint a site that said to do that explicitly, but it only made sense
Okay try this:
Btw: I'm using Ubutun 5.04 so i'm not sure if the commands are different...hopefully a guru can help
Open command line(terminal)
cd ~
cd .transgaming
gedit config
now scroll down to the "fonts" section
you will see
;"FreeType" = "N"
repace that with
;"FreeType" = "Y"
done...
one more thing~ if you scroll up you'll notice a qusetion "how much vram do you have?" and by default it seems to have 32...i changed mine to 128, and i hope that was something that makes sense
and one more thing~ I use gedit which is obviously for gnome....you don't necessarily need to use that~ use vim if you want..its just a text editor...
