CDs make popping sound
MidiGuy
Hey! I'm using the on-board audio on the Soyo SY-K7V Dragon Plus!, and when I play a CD in my CD-ROM (a Delta 52x), I get a popping noise (it seems like it might keep in time with the hard drive accessing, but I'm not sure of that). If I let Windows Media Player (this is WinXP, by the way) rip the audio, I don't hear much, if any, popping in the recording. Anyone got and ideas about how to make this go away?
Thanks!
-Midi
try enabling digital audio, and see if you still get the popping sounds, if not, then you are most likely getting inteference ..
-neural
Ok, here's the latest. I'm not sure where to enable digital audio (I remember a setting for that in WMP, but I can't find it in this version). If I put a CD in the drive and push the play button on the drive itself, I get no popping (and, in my opinion, better quality sound). If I play the CD through WMP or the AudioRack program that came with the mobo, I get the popping. Also, when there is a CD in the drive, if it's spinning, even at a low speed, I can hear a low hiss in my speakers whenever I move my USB mouse! I also just noticed it when I held down a arrow key on my keyboard to move the cursor in this text box. What is that about?!
go to device manager, cdrom's, and hit the properties of the drive, and hit advanced settings and hit enable digital audio, you will need to reboot ..
you are having some issues, i think interference is playing a part of it somewhere , try that and see what happens, and also, disconnect the audio cable from ur cdrom altogether .. and see what happens ..
-neural
Ok, that didn't change anything, so I turned it off, disconnected the CD audio cable, turned back, and still no change. I only unplugged the cable from the CD-ROM drive, not from the mother board. Does that matter?
