CDRWIN and Xp problems?
moonsocket
anyone have problems using cdrwin and XP? it says i dont have a cdburner installed ...hmmmmmmmmmmm
got the updates and everything.
any help would rock
chris
i don't have a problem. are you using the 4.0A version? is your burner supported by CDRWin?
and ASPI layers installed? v4.60? download forceASPI if you need to. i had to do that to get it to work.
