CDRW Maintenance Question
godot
25
1) how long is a CDRW drive's life expectancy in terms of number
of CD s burned?
2) how often do i need to clean/add oil to the drive?
thanks.
madthumbs
Banned
Oct 1, 2000
2,680
CDRW's should last til obsolescence, but you can check the manufacturers documents for each CDRW's life expectancy. They "should" never need cleaning or oiling. I suggest just trying to keep it clean as opposed to cleaning it.
