CDRW and burning problem
Henry Kuo
2,248
I have the Acer 8/4/32 CDRW. I have tried EZCD and Nero. When I burn a 74 mins CD, no matter audio or date, it's fine. 100% success rate. But when I put in a 80mins CD, the failure rate is 100%. Why is that? I have upgraded my CDRW to the newest firmware, and I am using the latest version of EZCD and Nero... Thanks.
Homerboy
30,890
5,001
I dont kno wwhat to tell you, but I CAN tell you that I have Acr 6/4/32 and burn 80min CDs without problems (using EZCD, CDRWIN, FireBurner, Nero etc)...
it works... I jsut dont know why yours doesnt? what brand CDR 80min you using? and what is the file size/time your trying to burn?
BCYL
7,803
If you read Nero's help files, only a number of CDR or CDRW drives support burning 80 min CDs. Check Nero's help files to see if your drive does support that feature.
I believe you also have to do some additional configuration in order to burn 80 mins CDs successfully also... again, check Nero's help files for more details...
Henry Kuo
2,248
i tried using the smart & friendly 80 mins cdr...... hmm.... maybe i should read the help files and see if i can get the driver update or something..... thanks guys.
