CDROM jumper settings.
Lopyswine
214
is there a website that has like a database of jumper settings for different manufacters?
BHeemsoth
2,738
check the manufacturers site...or post your drive here. Someone may very well have the same one.
CraigRT
31,440
there are usually 3, topps 4 choices.
ain't gonna hurt if you plug the drive in with the incorrect settings.
i'd say for the time it takes, just try any settings and plugging the drive in until it works how you want it to be.
(assuming this is the problem)
DaTT
Garage Moderator
Moderator
Feb 13, 2003
13,295
122
In my experience, (looking at the drive from the back) left to right -- Cable select, Slave, Master. This probably is not always true, but its something to start with.
techietam
774
If it's an IDE drive, it'd be just like DaTT descibed.
If it's a SCSI drive then it gets much more complicated :)
