A austin316 Diamond Member Dec 1, 2001 3,572 0 0 May 27, 2005 #1 From the dropdown list, I can only select my AXV virtual drive, not my NEC DVD drive. Anyone know how to fix this? Thanks.
A austin316 Diamond Member Dec 1, 2001 3,572 0 0 May 27, 2005 #3 Originally posted by: ShadowBlade i had the same problem Click to expand... were you able to fix it?
A austin316 Diamond Member Dec 1, 2001 3,572 0 0 May 27, 2005 #4 Figured it out. Click the box ----> Use native NT SCSI library.
