Hey guys,
I have a problem with my father-in-law's pc, and I was hoping someone might be able to help.
We've tried to get a CD to copy straight from the CD-ROM to the CD-RW 3 times, and each time the process errors out. He's using Nero 5.5 with a Lite On 16x10x40x CD-RW, and the CD-ROM is a 12x, so we're limited to burning @ 12x. We've also tried burning @ 8x just in case it was a problem w/ the CD-ROM only reading @ 11x. (hope that makes sense?). The CD-R's we're using are PNY 12x's.
First of all, I don't even know if this is the cause of the problem, but since he has 2 HD's, 1 CD-Rw, and 1 CD-ROM, we had to connect the 2 HD's together on one IDE cable, and the two CD devices together on one channel. This is because the master and slave connections on the 18" IDE cable are so close together, that they won't allow us to connect one HD to one CD device. (he has a large tower, and the inside configuration is less than optimal). When we started NERO, it said that since we had 2 CD devices on one cable, that there could be a problem copying straight from the CD-ROM. Does anyone have their system set up like we had to configure his? Does it work ok for you?
Is it possible to switch the cable around, so that the connection that usually goes into the mobo, instead connects to the CD device? That would allow us to connect one CD device to one HD for each IDE cable.
Or do they make cables longer than 18"? I just went to the local computer store, and the guy there said they didn't, but I'd just like to verify that 🙂
Thanks in advance for any help!
Viewton
Viewton
