Can someone help me. My kids' computer will no longer install any software from the CD-ROM. Usually it gets from 10% to 50% installed and then seems to time out on a large file (though I am just assuming the files are large). The CD-ROM was the master on the second IDE and also had a DVD-ROM attached to it as a slave. Since the DVD worked perfectly and installation from it was no problem. I figured it was a bad CD-ROM. I replaced the CD-ROM with a new CD-RW and the same thing continues to happen. I assume the IDE is ok and the cable since the DVD works perfectly.
Also, I do realize that some games have this problem and they usually have fixes at their websites. However, this seems to be happening with every game we have tried to install, even ones that we installed before with no problem, uninstalled for one reason or another, and now wish to reinstall.
Any other ideas or suggestion would be greatly appreciated. I am stumped!
