Just thought people would like to know what I have found with a bit of messing around.
My machine
Santa Cruz
Win2k
Pioneer DVD-106s
My SC is connected to my receiver digitally through coax, I wanted to avoid all the anolog stages and have only a digital stream being passed from the computer and decoded by the DAC in my receiver.
This was not a problem with .WAV's etc but CD-Audio needed a little experimentation.
At first I plugged the 2pin digital cable into the back of the pionner and then into the SC, no CD-Audio. Tried the 3pin Anolog cable and CD worked but this is not what I wanted but then I found out there is an option in the device manager to enable cd digital audio through the pci bus I enabled this and was happy. Someone then mentioned that CD-Audio should now be controlled by the WAV mixer tab and not the CD one, I mute my CD and the music stops, eh? Opened the case pulled out the Anolog cable and my CD-Audio was now controlled by the WAV tab on the mixer and not the CD tab.
So basically:
Digital out on the Pionner 106 slot DVD does fcuk all.
An anolg CD-ROM audio cable will overide the 'use digital audio' setting.
Hope that helps somebody
Peace
My machine
Santa Cruz
Win2k
Pioneer DVD-106s
So basically:
Peace
