I'm puting in a burner alonh witha cd-rom and It recommends putting the burner on a channel by its self so you can do on the fly burns. The cabel wouldn't reach so i had to set it up so both the cd-rom and burner are on the same channel. Now it will burn about half of a cd, but then gets an error and quits. Are there any work arounds other than buying longer cables, or copy th ecd to hd and then burning?
Thanks,
Sean
Thanks,
Sean
