I'm having problems with my LITE ON LH-20A1L SATA DVD-RW drive. It started with COD4. Game installed properly, but when I try to play single player, I would get a "Please insert correct DVD.." error. This was without removing the DVD after the install.
I just re-installed CDXP BURNER PRO, an open source CD Burning program which I've used for quite awhile, and tried to copy some files to a CD-R disc. The files could not be written to the cd. Now, NO cd or dvd I insert in the drive can be seen. When I click on the drive in My Computer, I get a "no disc in drive" message, no matter what is in there. I uninstalled CDXP BURNER, but that didn't help.
Hardware Manager > properties for that drive says drive is working properly. I tried uninstalling the drive in Hardware Manager and rebooting. The drive will show up again in Hardware Manager after reboot, but still same problem. Windows says it can't find a better driver than what it currently has. Using standard Windows driver, LITE ON doesn't provide a driver. I've updated the firmware, @ LITE ON's suggestion, even though it's the same firmware that was default.
My first experience with SATA cd/dvd drives. Does the problem have anything to do with the SATA aspect?
Any suggestions?
Thanks
Any suggestions?
Thanks
