CD drive not recognized
overst33r
My CD burner is suddenly not showing up in my computer. I have a inspiron E1505 and i went under administrative tools, under disk management, only HDD is found...no optical drive.
The model of the drive is HL-DT-ST CDRW/DVD GCC4244
I put in a CD, the drive spins up and light flashes but nothing happens.
I have already reset defaults in BIOS
Under device manager it has a yellow exclamation mark. I uninstalled it, restarted, windows says it found new hardware...i let it install...go under my computer...nothing.
I am unable to find any drivers for this drive, i figured windows would have them since it should be plug and play.
What else can i do, short of reformating...
Thank you for any help on this issue.
Are you using the Dell install of Windows or did you write over it with a different version?
If you replaced the Dell Windows you may be missing the motherboard / chipset drivers.
