I just bought a 24X Acer CDRW.. but.. Nero and Easy CD 5 both only allow 20X.. Sometimes when I'm not going to burn anything.. it gives be the option to burn 24X.. any suggestions??
Thanks~
Does nero and EZ cd creator 5 correctly regcognize your burner? If not you might need a firmware upgrade or possibly have to make sure your burning software is current to correctly support your new burner
