CD burner having problems reading CDRW's?
dcpsoguy
I just got some Memorex CDRW's, and it's clearly in the CDRW drive and it says it won't read it. What could be the problem?
Not on Christmas! Anyways, I think I found some firmware to fix it, BUT I can only find DOS versions of it, not windows. I have XP. How can tat help/
It's doubtful, but could it be the burning program you are using? (or are you just using XP?)
I meant the tech support forum here is where this should have been posted
it won't let you format the disk either?
Try another disk, or try their (memorex) tech support on the their website.
