CD Burner , CDRWIN and WinXP
err
2,121
Hi,
I have a WinXP with TDK 12/10/32 cd burner.
I am trying to get CDRWIN working on my system as it is the best cdr software out there that is so powerful.
Anyway, I know I got my software working in Win2K and it was burning fine.
Now, in WinXP, I can't even get it to install properly. I have CDRWIN 3.8c.
Has anyone get XP working properly with CDRWIN ? If yes how did you do it ? How about the ASPI mess that you need with all the other WIN based OS ?
Thanks for any inputs
eRr
bacillus
14,517
have you checked to see if there's an XP upgrade patch for your preset software or if you present version is XP compatible?
err
2,121
Ginfest,
Thanks for the pointer. I will test this out once I get out of work :)
I don't believe CDR-WIN is officially supported under XP.
eRr
err
2,121
Diable,
Did you have to do the ASPI update ?
Did you fresh install your XP or upgrade from Win9x, or Win2k ?
Did you have to copy the .dll that Ginfest had suggested ?
Thanks for your response !
eRr
