cd audio will not play::o
zduckman
30
confused;Windows media player keeps telling me to insert an audio disk
windows cd player says the same.
I have tried a new cd rom and sound card.
I have loaded win 98se back over the top of its self.
I have removed the enum key and reloaded all hardware.
still get message that I need to insert a cd audio disk. When I try to play an audio CD
the drive icon shows a cd audio disk is in the cd drive.
will play all other music files and formats
I did a fresh load of win 98se another hd and all installed hardware works fine cd players work fine.
I updated the windows media player from the original with 98 load to ver 7.1 and then to ver 9
still no darn cd audio
dell, p3 500,128mb ram,nvidia disply adapter,40ghd,32xcd,
AtTheGates
274
Is your cd drive connected through an audio cable or just by the IDE? Check the volume of CD Audio in the control panel.
zduckman
30
It seems to be a specific problem associated to CDA files.
cables are all fine. volume is all fine
connected to sc by audio cable.
drive works in another system
new install of os on a different hd works fine ..
zduckman
30
It was set to that.. undid the check mark no difference.. still says to instert an audio disk..
remove all references to winamp and music match from the registry and then will reassociate file
types to windows media again.. agggghhhh.. LOLOL
