CD Audio header
SunnyD
Belgian Waffler
Jan 2, 2001
32,674
www.neftastic.com
I recently got a new video card, which has a dual-slot cooler on it. It turns out, in their infinite wisdom, Gigabyte decided to put the CD-Audio header right behind a PCIe slot which gets covered by the video card cooler. It wasn't an issue before the video card went in (integrated video), but now I can tell the audio cable is getting mashed up against the shroud on the video card. Everything fits, but I know it's putting a little pressure on the motherboard and video card.
My question is - unless you plan on listening to CD's on your computer, is there any real reason to plug the CD-Audio cable in anymore? DVD's and games generally don't use CD-Audio anymore, does anything else?
VirtualLarry
56,571
10,207
With a modern drive, listening to CD audio happens over the IDE/SATA bus, not the analog audio cable.
imported_apocalypse
449
To use the headphone jack that comes with some optical drives. But most people don't use that jack or use cases that have front panel audio out.
bludragon
42
You won't miss anything by unplugging it, the only use for it is with an audio cd where the os does not support getting the audio digitally from the drive. I think this was an option in w2k, and is default in xp and I assume vista too.
Spicedaddy
2,305
77
Yep, and it's been like this since Windows 2000. (Win 98 needed it for Audio CDs)
