- Oct 25, 1999
- 272
- 0
- 76
Howdy all,
I need to take the signal from a standard cable modem
and pass it to a cable wireless router netgear cg3000D ( For reasons beyond my control I can't just replace the modem with the wireless cable router).
I hope to add a wireless signal and a couple ports by doing this.
my understanding is that since there is no wan access for the cg3000d that I have to
disable dhcp for it
and change its lan address to something that the cable modem can send to
then come out of the cable modem port and go to one of the cg3000d lan ports and I should be able to pass the signal on wirelessly and on the remaining lan ports of the cg3000d
I am not clear on what the lan address of the cg3000d should be set to and if any other settings need to change
I will provide whatever details are needed to help me understand the proper way to set the lan address etc. of the cg3000d.
Any help appreciated.
disable dhcp for it
