Catch something in a hot tub?
My sketchy friend just invited me to go join her and her friend Pam in her hot tub at her house.
Then a crazy thought came into my mind.
Is it possible to "catch something" sitting in a hot tub with someone else?
if you mean std (i) 's when you say catch something, the answer is no, if the hot tub is well maintained. people put chlorine in their pools to keep something like this from happening. this does not mean you can safely rub your junk against her while in the hot tub, though.
Dude, what is with you? Every time you have some plan with a chick you always are scared or act like a semi-homo bitch. Grow some nuts, or just cut off what is left of them and change your name to Ellen.
EDIT: Is this sketchy friend the one you were a cuddle bitch to? Or did that one showed you the door?
Originally posted by: kami333
And if it's not, an STD would be pretty low on the things you could possibly get.
It would be virtually impossible unless they start fooling around. We have five public hot tubs and four are within camera's eye and you would be surprised at what people do (and bring) in them. :Q
Originally posted by: Atomicus
you could catch a turd... and if you don't want to you can gently blow it to the other side of the tub 😛
Unless it's actually a Baby Ruth, then you just take a bite of it! 😉
Surprise me then!
you'll never know unless you try!
(did I just post that?):disgust:
If you're that worried about this person passing something to you, why is this person your friend and why are you even considering going?
