marblewave
Heya,
A few weeks ago, I upgraded from Catalyst 8.3 to 8.4 for my X1900XTX on Vista Home Premium 32 bit.
When the driver installed, there was a black bar about 1" wide, sort of like letterboxing, but all the way around my monitor (24" LCD @ 1920X1200).
I thought perhaps it was a conflict with the old drivers, so I uninstalled them and used driver cleaner in safe mode. I reinstalled the 8.4 but the issue came straight back. I uninstalled 8.4 and reinstalled 8.3, problem solved. When 8.5 came out I gave them a shot with the same bars showing up. Reverting to 8.3 solved the problem again.
Thinking it was a windows problem I did a clean install of Vista, but after tossing on 8.5 as the 1st set of drivers on the clean install, the problem was there again.
I'm hoping someone can either help me figure out why this might be happening or perhaps has had the same problem.
I appreciate any input you have.
Thanks!
Thanks!
