Catalyst Control Center Overdrive problem
MXtra
38
is there a way to turn this dam overdrive off in the ccc? i click on the padlock and it doesn't close. it remains unlocked and I can't figure out how to make it run at the old default settings. i actually get worse than stock results with this overdrive and I gotta shut it off somehow without reinstalling all the drivers. anyone can tell me how to do it?
hmorphone
345
Only way I know of to shut it off is to reinstall the drivers. If someone could tell you which registry key it is, then you could just edit the key and prob not have to reinstall. It makes no sense why you just don't turn the sliders back down or uncheck apply at startup and reboot. It also makes no sense why it's getting worse results.
