To clarify, everything works fine. Games will be rendered properly, and the display drivers install perfectly. However, whenever I run the Catalyst Control Panel, I get an error and am forced to terminate it. It goes:
CLI.exe - Application Error
The application failed to initialize properly (0xc0000135). Click on OK to terminate the application.
I recently removed a GeForce 4TI series card, un-installed the drivers before putting in the Radeon. I have Windows XP SP and have had no troubles running any of my apps EXCEPT for this Catalyst Control Center. I have un-installed/reinstalled this several times to no avail.
And on the side note, is there any application that retrieves what Core (R350/R360) this is, and also whether its 128/256 bit?
Any suggestions would be appreciated,
Thanks
Thanks
