- Apr 8, 2014
- 92
- 0
- 0
Hi
A couple days ago, i began to play Warface and i encountered artifacting issue. My GPU drivers were Catalyst 14.7 Beta, i uninstalled the driver and returned the 14.4 WHQL. Artifacting issue on warface has been solved. But yesterday i installed Wolfenstein and i saw artifacts on this game. Not only infamous İd Tech 5 texture pop-in but also some graphical corruption on the screen. Then i tried 14.7 beta drivers and the issue solved.
So my question is: Some users have problems on Warface with 14.7 but no one have graphical corruption on Wolfenstein:The New Order with 14.4. Then, why me? Older AMD drivers, Wolfenstein have issues even the game couldn't load, but not on 14.4. I tested my GPU on Furmark on long hours, there is no problem. There is no overheating issue on my card. I didn't overclock anything. I tried turning triple buffering on/off, V-SYNC on/off, lowering/increasing graphical details and none of them works on 14.4. What should i have done to play Wolfenstein on 14.4 WHQL. I said this problem on 14.4 is uncommon, is really it? And the most important things is: Is it only software/driver problem or the card has physical issue?
My system is:AMD FX-6300, ASUS M5A97 R2.0 with last BIOS update, Corsair 2x4 GB DDR3 1600 Mhz CL9 RAM, ASUS R9 270X DirectCU2 TOP, Corsair cx-750 PSU,, Win 8.1 Pro, default Catalyst Control Center Settings.
