situation:
house is 300 feet away from mailbox/driveway entry. View is blocked by lots of trees so wireless cameras are bad (most of them need clear line of site to work at this distance.
we are having a a lamp post placed at the driveway entry so they will be digging a trench for the power cable to go in.
I was thinking of laying down outdoor cat5e cable alongside the power cable when they dig the trench. I was thinking of using CAT5e since it would be cheaper than running a coaxial or rca line that long. Plus it will have extra unused wires in case I want to add other things in the future (another camera, or pan and tilt control, power to heat enclosure)
question:
1. will the cat5e have problems running the low voltage power supply and RCA video feed together.
2. will the cat5e be able to hold the RCA video signal up to 300 feet?
3. good idea ? bad idea?
4. Anyone know of a good night vision wireless camera under 200$ that can go about 300 feet partially obstructed?
I figure 50$ for 300 feet of cat5e, 100$ for a wired external infrared camera.
I am aware that there are grounding issues,insurance issues running copper wire outside your house.
I figure that someone here has used cat5e cables for other purposes, I know people have made VGA cables using them for there projectors.
peace
question:
peace
