Cat5 riser is rated for the vertical runs. Almost all Cat5 is riser these days.
Cat5 plenum is rated for use in air plenum spaces in the heating and air conditioning system. It will not give off noxious gasses in a fire. Riser puts off poisonus gas when heated or burned.
Many buildings use the overhead space above a dropped ceiling as a "plenum" or portion of the ducting system, hence the need for a safer cable. In a regular house situation, plenum is unnecessary.
