Cat5 Cabling max length?
jai6638
1,790
Hey. ... Whats the max length of CAT5 cabling ishould use? i need to connect 2 computer in 2 differnt bedrooms ( with a livingroom in between ) .... i wanna minmize the loss of bandwith..
thanks
JackMDS
29,563
432
The Standard is:
16.4' (5 meters) Patch from wall to computer. +
295.2' (90 meters) Horizontal (in the wall or under the carpet etc.) +
Total =328' (100 meters)
You would find people claiming Good Connection using 400'.
But that is like buying a Ferrari and using it with Regular gas.
:sun:
jai6638
1,790
I need some help here.... I have a netgear wireless B router and was wondering if i should go wireless or stick to cabling? the reasons why i wanna stay away from wireless are as follows:
1) dont trust WEP a lot coz im pretty sure there'll be someone who'd wanna use my bandwith ( given that i live in an apartment complex )
2) i personally think that there would be some bandwith loss due to distance as well as inteference from my phones,walls,etc
Your help in this matter is appreciated
JackMDS
29,563
432
jai6638
Philosophically, I see it similar to: "I am Not going out since I might be involved in an Accident".:shocked:
1. With Decent security the probability the some one will still your Bandwidth is Low.
2. Yeah my 802.11g is slower then Wire.
However it is not affecting Internet activities, and I am not using it for Heavy File transfer. So for my use it is as good as Wire.
In other words, it is a personal call.:beer:
Link to: Wireless What Should I Get?
Link to: Wireless Security.
:sun:
madthumbs
Banned
Oct 1, 2000
2,680
Because of the topology of ethernet, you would probably be best to place the router in the living room. Already mentioned by JackMDS, 100 Meterrs or 328ft is the theoretical limit. For internet, wireless is definetly fast enough.
ScottMac
Moderator<br>Networking<br>Elite member
Mar 19, 2001
5,471
To supplement Jack's (correct) earlier post: the "90 meters" in-the-wall MUST be solid core cabling.
Stranded core cabling is used for jumpers (handles more flexion beofre breaking). Stranded has much higher loss than solid core.
FWIW
Scott
spidey07
65,469
and to add 90 meters solid core with 5 meters on each side isn't a "theory" limit or max. It is what ethernet is designed for. Folks run 1000 Base-T on 90+ meter runs all day without any errors whatsoever.
