Cat 6 cable plugged into cat5e jack?
de8212
House is wired with Cat6 cable which is punched down onto Cat5e wall jacks. I had cat5e cables connected to the router. Everything worked fine. Switched the Cat5e cables out for cat6 cables and both main PC's work intermittently. I don't have a cable tester on me (brother in law does so he took all the cat6 cables). Dumb question but there should be no issue plugging a cat6 cable into a 5e jack, right?
correct. Both are terminated to RJ45 and either TIA568A or B. The only issues you may have are:
1)bad cable
2)crossover cable on non-gigabit hardware.
3)coincidentally something is wrong now with one of your keystone jacks or wire runs. Coincidences like that do happen.
If you mean the keystones are cat5e but the house in wall is Cat6 then technically your out of spec as cat6 is a different diameter. However cat6 is larger than cat5e you might be ok but in theory the punch downs could be poor because crushing a larger core in to the smaller cat5e slot can break the copper in the cat6 in wall. If you mean cat6 patch with cat5e everything else, that is fine.
thanks for the info. I'm hoping bad cable but it seems strange that several of them are bad. Hopefully he will test them today and let me know. I really need to get a cable tester of my own.
I don't think they were xover. Well, I should say I didn't order xover. Here's the link for one of them. Click....
Hopefully keystone jacks are fine. I put the old cat5e cables back in and everything worked 100%.
My whole goal was to get short cables and help de-clutter my network closet. It looked great but didn't work reliable. I may just order some cat5e 1ft. cables and be done with it.
When I had the house built I had plenty of cat6 cable to run through the walls but could only find the cat5e leviton keystones at Home Depot, no cat6. So that's why it mixed.
