- Feb 1, 2003
- 881
- 0
- 0
Is something like 50ft Cat 5 cable usually just one cable or is it usually just the wire with no ends so you ca make custom size cable?
Originally posted by: amdskip
Depends on where you get it from. It should specifically say with or without ends on it. If you want a patch cable, a machine made one will be of much higher quality than you can crimp one.
Originally posted by: Evadman
I have never had a problem crimping my own cables. I bought a 1000' cat5e spool from home depot for $59, a crimper for $60, 100 ends for $15 and a tester for $80. This was about 2 years ago.
For that $200 investment, I had all the cables I could ever need. I ended up using up that 1000' spool in about 6 months making cables for people. 1/2 of another spool was used up in wiring someone's house. I have made my $200 back 10 fold.
It was very easy, and I am still using the cables I crimped oh so long ago. the cables are all solid core, which is not recomended for the patch cables I am using them for, but I have yet to have a problem.
What's wrong with solid core cables?
Originally posted by: Lord Evermore
For the average person who knows nothing about them, buying retail patch cables CAN cost an arm and a leg, depending on where they go.
Originally posted by: spidey07
here's an interesting story.
i was in training all last week. The network guy there made all of his own patch cables, scoffing loudly at how good he was at it and how stupid it is to buy patch cables.
The classroom network would go up and down a few times a day. We traced it to about 6 of the patch cables and replaced them. No problems afterwords.
It is still a very bad idea to make patch cables.
