those cases usually have the board inverted. (the cpu is slotted at the bottom and the video cards are up top.)
i havent seem them anymore, as inverted setups were considered unique and expensive builds.
You may look for a Lian Li V series.. (example)
but they were discontinued.
The silverstone TJ07 series also had a feature where u could invert the board, but required some moding, and was also very expensive.
The silverstone Raven had a 90 degree rotation, also had a window on the right side, is also probably the youngest out of the 3 i listed, but lacks usb3.0.
http://www.newegg.com/Product/Produc...82E16811163173
However again, its discontinued.
But in short, inverted setups arent that great... i have both the Lian Li and Silverstone TJ07.
both dont offer USB3.0 as i said inverted board setups have mostly died out, and never got to the age of USB 3.0.
What i would recommend more is horizontal board layout.. meaning the board lays down flat, and the top has a window like a MM Hori design, or the cheaper solution:
Cooler Master HAF XB EVO
http://www.newegg.com/Product/Produc...-265-_-Product
this way u can either mod a window on either side or both side, or the TOP even, and get what your wanting on multi orientations.
