Case with Power supply under 100$
Which one is the best choice ?
  • 1 - Cooler Master: K380 ( with Power Supply )
  • 2 - Cooler Master: Elite 311 ( with Power Supply )
  • 3 - NZXT : Source 210 + Power Supply : Cooler Master Extreme Power Plus 460W
  • 4 - NZXT : Source 210 + Power Supply : SeaSonic ECO 500W PSU
  • 5 - Thermaltake - Commander MS-I ( with Power Supply )
  • 6 - Thermaltake - Commander MS-III ( with Power Supply )
  • 7 - Thermaltake - Versa G1 ( with Power Supply )
  • 8 - Thermaltake - Versa G2 ( with Power Supply )
So these are your only options?
Usually any power supply that's supplied with a case is not very good. However there are exceptions. The links you provided don't show what the supplied PSU is, so can you please find out. I don't mean wattage I mean the exact part.
What hardware are you planning to power?
The Cooler Master 460W isn't very good, it can't supply 460W of power cleanly. It's more like a 370W unit in reality.
Can you get the manufacturer part number of the Seasonic ECO 500W, I can't find any info on it.
The Cooler Master 460W isn't very good, it can't supply 460W of power cleanly. It's more like a max. 370W unit in reality.
I need power supply 400W
Okay, but...
Can you find out which exact power supplies are supplied with the cases?
Can you find out Seasonic ECO 500W manufacturer product number?
Okay, but...
Processor : Intel® Core™ i3-3220
Motherboard : ASUS - P8B75-M
Graphics Card : SAPPHIRE HD 6670 1GB GDDR5
Memory : Corsair 8GB ( 2 x 4G ) Dual Channel
Hard Drive : WD Blue 1 TB SATA Hard Drives ( WD10EZEX)
Okay. I'd probably go for the Seasonic... Did some more googling and it seems the Seasonic ECO 500W is SS-500BT, an 80+ bronze unit covered by 3 year warranty and actually built by Seasonic, not some third party. Should be fine.
No... the poll is rubbish as it lacks the info about what psus are included with the cases
Never seen someone put together a system using polls before.
http://forums.anandtech.com/showthread.php?t=2346964&highlight
http://forums.anandtech.com/showthread.php?t=2346842&highlight
How did you come up with the 6670 without a poll? You need to post that poll up or your streak will be broken hairy ahmed!
We need a poll to ask whether there are enough polls? Perhaps you could oblige!
Pick a number, go on, any number!
