Case with Neon light and many fans.
faye
2,109
Hi, i saw so many cool case that has fans and windows on the side door. and there are neon lights behind the windows so it looks quite good...
i am wondering if putting too many fans (like total of 3 fans in the case), will this make the case very noisy?
ya, i do want to buy a case that is quite cool and quite and also support INTEL and AMD.
cheap also...
any suggestions?
oh ya, currently i have a InWin 17" case with a P3 configuration... wondering if this case do support P4.... it just has 250w of power. (fan on the PSU, total of 1 fan)
MattTheTech
90
3 fines isnt that many (no im not saying you should get more :) you have plenty), so i wouldnt worry about sound unless you get some really cheap fans. from my experience, most fans are fairly quiet until they get enough dust to unbalance them just a tiny bit :p
as far as supporting intel and amd... i dont know of any standard ATX case that doesnt do that allready.
and for that p3 you have, look up the info on the motherboard to see if it would support a p4 (if its a slot type p3 it definently wont), i would really recommend getting a 400W ps (or at least 350W) for a p4 though.
faye
2,109
oh, my motherboard surely doesn't support P4...
i am saying a case that support P3, will it support P4.
Gonna put a ATI 9700 pro or a GeforceFX in the future...
so i want to give them plenty of juice.
