- Jul 27, 2002
- 13,314
- 690
- 126
As the title says. I swap out parts fairly often so I'd like to get a case with removable motherboard tray. I personally think the time for anything smaller than 120mm fans is gone, so I'd prefer 120mm fans and mounting holes for them in the case, but if the case is a good quality then I'll still consider even with smaller fans.
I'd try to search on my own but some of the cases I found are fairly old. Is there something recent from reputable companies?
Thanks in advance.
Thanks in advance.
