alexruiz
I am upgrading my comp, and the parts for the new parts are already in transit. I have almost everything except the new case (the old case is ugly, and using it means downtime also). I am looking for something decent looking, not very expensive, PS not a concern (I have a spare one)
The only requirement is that it should have front ports (USB and audio are common). However, in addition to the standard, it MUST have a firewire port in the front.
In the cases that I have seen, the ports are located at the bottom
Do you know of a case that has the front header in a more reasonable location? In case there is none, or if it is too expensive, I will have to go with a case that has the ports at the bottom.
Make your suggestions!
Thanks
Alex
Thanks
Alex
