- Feb 21, 2005
- 43
- 0
- 0
I just put together my new computer. It's as follows:
Athlon 64 3500+ Winchester
XP-120 & some generic 120mm fan currently running at full tilt (12v)
BFG 6800GT OC
DFI Lanparty SLI-DR
Lian Li PC V1100
Those are the specs that matter at least. When I check my temps with ITE Smart Gaurdian it reports as follows:
29C idle - 36C load CPU
44C idle - 51C load PWM IC
43C idle - 50C load Chipset
The CPU temps seem fine, the other two I'm not sure about. I'm not even sure what PWM IC is. But I'm wondering why the chipset and the PWM run significantly hotter than the freakin CPU. When I touch the XP-120 its barley warm, but the CPU temps are good, the chipset on the other hand definatly feels warmer. Why would this run hotter? Is somthing wrong?
BFG 6800GT OC
DFI Lanparty SLI-DR
Lian Li PC V1100
