Case switch/LED header
WildW
984
20
evilpicard.com
Just a random thought that occurred when I was plugging in case switches and LEDs to a motherboard this morning. . . how come this connector isn't standard yet? (Or is it? I haven't bought a new case in a couple of years)
I couldn't plug in my power LED because the case's connector was 3 pins long, but the motherboard had just two pins for that. I remember USB connectors inside the case being a bunch of separate pins, probably about 10 years ago, and they managed to standardize those.
mikemcc
86
Hmmm... That is really weird. I should remember this because I just did a build a couple of weeks ago, but I thought the power LED was always two pins. Polarity doesn't matter on the power LED so you can plug the connector in either way. I thought this was universal -- I can't think of a build I have ever done that is different. Does the manual for your case say anything about what the three-pin connector is for? Are there actually wires that go to each contact in the connector?
WildW
984
20
evilpicard.com
Sometimes they are 3 pin for no reason.
It's really more a question of "Why isn't it just one big connector instead of a bunch of separate ones?"
BonzaiDuck
16,889
2,208
Basically, for a mobo with two pins side-by-side, there's a possibility you could simply use a sharp-pointed tool to tease out one of the pins in the three-pin connector, to then re-insert it to the middle position. The only way this wouldn't work: your motherboard pins accept plugs from both sides which make it impossible to fit the three-pin plug.
Just in passing, I don't think I ever saw a Power-LED cable and plug that wasn't just a two-pin construction. I almost thought you had mistaken the motherboard pins and labeling, because the "speaker" connection (a four-pin plug) is just opposite the Power LED or Reset pins on my own motherboards. But that's not the case . . .
mikemcc
86
I agree with BonzaiDuck -- if your MB posts are at the end of the block, just move one of the wires to the middle hole on the connector and then plug it in, leaving the open hole hanging off the end. Doesn't matter which way you plug it in because polarity for the Power LED doesn't matter. If, for some reason, your MB posts are not at the end of the block, do you happen to have a two-prong connector laying around anywhere? An old case, for example? Just cut that off, take out the wires, and then put the wires from your new system into that two-prong connector.
Just curious -- what case is this from? I'm wondering if they had some kind of mistake at the factory because I can't figure out why they would do this for a power LED.
As to why they don't make one big connector to plug in all those tiny wires, I don't know. Someone with big ham-hands like me would appreciate that. On one of my old ASRock boards, they did have something like that. I think it was called a Q-connector. But different motherboards place the pins in different orientations so they aren't universal. One MB doesn't necessarily have every pin that another MB might have. For example, my newest MB makes you choose between a HD LED and a Power LED, while many MBs have pins for both. I chose to use the HD LED because it flashes every once in a while and I always know if my machine is on anyway, even though it is silent unless it is under a pretty hefty load. And cases are different too. Some, like my Fractal Design R4 don't have a case speaker so those pins on my MB aren't covered.
WildW
984
20
evilpicard.com
The case is an old Antec NSK4000 something. . . there are a ton of versions of it and I think mine is an older one. I can live without a power LED, it's no big deal.
Everyone seems to think LEDs work with either polarity I notice. I used to be sure that diodes didn't work that way, but I can't say I've actually tried on a PC case one lately.
But why in 2015 am I still doing all these connectors separately? :p
