Case Recommendation
mystikmedia
12
I'm looking for a lightweight case for a future Intel Extreme Edition (quad-core) system. I'm thinking aluminum alloy may be the best option for very good construction while still being lightweight. I want to overclock as much as possible. So, it needs to have very good cooling abilities. Will most likely add water cooling and whatever else needed to keep it cool. It should have a minimum of two front USB ports. I would like the USB ports and power button to either be on the top of the case or on the front-top. A reset button would be a plus. If it has a front door, I would like for it to be the "one on both sides" style that meet in the center. Wheels or some sort of handle(s) would be a plus. The left side of the case may be against wood (the side of a large desk). So, the cooling elements should be in other locations. What do you all suggest for this scenario? I am after a high-end solution for the best resolutions. Great looks/style/etc. are always a plus, but not a requirement.
genec57
135
If you will look through the large selection on newegg.com I am sure you will find the right case for you.
I am continually amazed at the number of people who want others to do all their research for them.
Zepper
18,998
The Antec p160W is a very nice case if you like the looks of it - they have some in their B Stock store for only $80. +sh and perhaps sales tax. Provantage has them new for $105. +sh. Super for a 1.2mm aluminum case with a lot of nice features - just from frequently looking at picture galleries of it I'd give it a 4+/5 on my Casitude (tm) scale. It's about 3" taller than most mid-tower cases so you can find some space to tuck stuff away. Under 15 pounds net wt.
.bh.
tranja
13
Check out the Antec 900. It comes with 2 front 120mm fans, 1 rear 120mm fan, 1 200mm fan on top of the case, a place for 2 more fans which I added 2 aerocool turbines 120mm. Have a Thermaltake V1 chip cooler and my chip temp w/ uguru has never gotten over 26 degrees. HOWEVER, I am not a gamer. My chip is an e6850 on an ABIT P35 Pro mobo. Pretty blue lights too
