Hi everyone, i'm putting a computer together for the first time and my roomate is helping me. I'm getting this soltek motherboard null and i was wondering what case you all would recommend that i get to the most out of the usb ports and extra audio expansion. Thanks.
It comes with an I/O shield, so you do not have to worry about the extra audio ports for 7.1. What I will recommend is a case that is at least 18.5" deep, because that board is enormously long.
What i'm looking at right now is this but obviously, the I/O shield doesn't match up with the usb and lan port and what not, what would i need to do to solve this?
