Case questions.
aznxk3vi17
123
Do you really, REALLY need all that room? It seems kind of overkill.
I recommend the CM Stacker 830. About the same price, more conveniently sized, great airflow design and looks, and great toolless design as well.
PCTC2
3,892
33
FYI, THAT CASE IS HUGE.
You do not realize how huge it is until you see it. It is made for two motherboards, a standard ATX/BTX and a Mini-ITX board.
And it is also made for a 7" touch-screen display.
Simply
31
Yeah I need a lot of room And Most the case above is toothless if you so desire it to be. All pci slots are a toothless design. plus to me itt looks better then case you suggested but thxs. Now if i can find a good cpu cooler for my mobo and fans.
