Case Quest - Help
Lalakai
In the near future I'll be building a new system but still haven't settled on a case. I've seen a couple "package" systems w/cases that had some ports in the front of the case, allowing you to plug in USB or video cables. Does anyone know where these types of cases can be found???
any input would be appreciated. thanks.
Cooler Master makes some of their Aluminum cases with USB ports in the front, but they are so expensive!
Tony
Electroseller.com has cases with front ports, they do it with a cable gizmo. These are not high end cases, and have Deer PSU's, I think.
If you just want front USB, there are bay hubs that connect to some of the newer mobo's additional usb headers. Dunno exactly where to find one...
