Good guide from VHforums.net:
Case Modding Supplies:
Rustoleum spraypaint
Clear paint
Primer (gray for dark colors, white for lighter ones)
[all automotive type]
Small lettering [
http://www.virtual-hideout.net/articles/project_tivoli/050.JPG]
Rubbing Compound
Machine Glaze
Guide to painting.
I?ve made this guide to answer the constantly repeated question in the forum "how do I paint my case?". In this guide I will include everything you need to know to get started painting your own computer.
Step one: Planning.
This may be one of the most important steps of them all. Know what you want to do and the colors you want to do it with. There is nothing worse than getting your case all painted and then decide you dont like the layout or the color choices. It can be removed and started all over again but that costs valuable time and money.
Step two: Preparation.
Some people like to sand to the bare metal, I don?t fine this necessary. I start with 180 grit 3m AutoPak wet/dry sand paper. Sand under running water until the texture is gone. Then use 800 grit in the same brand paper. this should give you a smooth surface to start painting on.
Step three: Spraying information.
There are a couple factors in this step. First off use the right kind of good quality paint (read below). Second, don?t paint when its real humid outside - it will cause the paint to mess up and not stick right. Ok, now that we got that out of the way always spray past what your painting. This means start spraying before the spraying the object and keep spraying until the paint has past the object. Paint in a steady strait motion. This will reduce uneven coats and insure a good job.
Step four: Primer.
Spray the first coat of primer keeping the nozzle about 10-12 inches from the surface of the area painting. Don?t spray it thick, several thin coats are much better than one thin coat. Let cure for one to two days. Just because its dry to the touch doesn?t mean that its cured. Once cured wetsand with 800 grit sand paper, the same grit you used to finish smoothing the surface.
Step five: Paint.
Spray the first thin coat in the same manner as the primer. After it has cured wetsand with 1000 grit sand paper, repeat. Spray another coat of the same color. Let cure then wetsand with 1200 grit sand paper. Spray another coat. Let cure, sand with 1500 grit wet sand paper. Let set for a day to insure that all is cured and ready for clear coat.
Step six: Clear Coat.
Spray thin coat of clear gloss coat, let cure for two days. Wet sand with 1800 Grit sand paper. Spray one final coat of clear, let cure. Wet sand with 2000 grit sand paper.
Step seven: Rubing compound.
To remove the 2000 grit scratches use a rubbing compound. Follow instructions on bottle.
Step eight: Waxing.
Basically follow the instructions on bottle/can. Don?t wax in direct sunlight it will make it melt to the case which is not good. Also use a good wax (read below).
Things you will need:
Primer
Paint
Wet Sand Paper- grits 180, 800, 100, 1200, 1500, 1800, and 2000
Rubbing Compound
Paint
Use a good quality. Buy either automotive paint, model car paint (spray kind, not the kind in the little jars), or Rustolium paint. Using paint that?s not high quality will make your case look like crap.
Curing
Curing is the process of the paint hardening. if you start sanding before the paint is cured than you will mess up the paint job. Just because it is dry to the touch does not mean that it is cured. I always let paint set for at least 1-2 days, this may seem like a long time, but its worth it.
Brand of product
If you start with one brand of paint, use that brand for the whole project for the best results.
Wet Sanding
You may be asking "why do I need to sand all those coats?" well the reason is because you want the best quality for your case. Why would you spend the time to and paint it if you were just happy with a cheep paint job that is going to make people laugh instead of stand back in awe. Basically wet sanding takes off all the high spots and makes for a much smoother higher quality finish. To wet sand you want to get your sand paper, something to lay your panels and bezel in while sanding, and running water (ie facet, water hose) let the water run over the surface your sanding (don?t have to be a lot, but a small steady flow). Hold the sand paper in your hand and sand it don?t, but don't apply much pressure. Let the grit do the sanding not the pressure of your hand, the idea is not to remove the paint it is to smooth it.
Painting Environment
Paint in an open place with a good air supply. I paint under my carport while spraying then bring it inside in my laundry room while drying so depressed bugs don?t make a death plunge into it. Paint somewhere where there is not a lot of dust or where there is a possibility that it will be stepped on or knocked over. If you?re painting on the ground, lay newspaper down first. Also try not to paint your hand, its easier to do than you might think.
Tip: set spray can in hot water for five minutes before you spary to increase pressure inside can to make a finner spray.
Tip: hold can upside down and spray a few seconds untill it sprays just air after every time you paint to keep from stuff building up in nossel.
Ok well this is everythig you need to know to get started and more. If you still have any questions email me any time at
TheSilentChamber@aol.com
This was written by TheSilentChamber, you may pass it on but give recognition where its due.
There is no need to respond to this, it was written to provide a easy answer to those who ask how to paint there case. If you feel something should be added please email me or PM me and I will look into it.
