Hey Everybody,
I'm building my first machine and am doing some research before I start ordering.
I found a Case-Power Supply combo on Newegg and I was wondering if the 350 watt power supply would be enough for what I'm trying to run.
Here's the item on NewEgg:
http://www.newegg.com/app/view...tion=11-119-057&DEPA=1
I plan to get an Athlon 64 3200 or 3400 and pair it with a PCIe ATI X800 XL, most likely the PowerColor card when it comes out, which does need a hook-up to the PS unlike other X800s. I'll be running two IDE hard drives, a DVD Drive and a CD-R drive, and most likely use the sound from the montherboard, or perhaps my old SB live! value PCI card. Beyond that I think the only other power draw would be charging my ipod via firewire.
Down the road, I plan to eliminate the optical drives and go with a single DVD-R/W drive and give my old DVD drive to my roommate who does most of the burning in the apartment. Also, I may also get an All-IN-Wonder video capture card if I think the VIVO on the X800 isn't cutting it.
So, is the 350 Watt PS good enough for my needs or will I need something bigger, say 420W? And how does one go about determining that?
Thanks
Thanks
