Case Modding
anox3
108
How many of you are into case modding? How many have went as far as putting all the wires into shrink wrap and adding lights? The main purpose for this question is how hard is it to remove the plastic molex and atx connectors and put them back? I know they make a tool for this to remove them but how do they go back on? snap on or just push back in? Thanks
CraigRT
31,440
most shrink wrap or sleeving kits should be able to fit over the connector ends, i know decent sized shrink wrap will.. i haven't gone that far, because i bought a modular power supply where the cables were already all done... but i do want to do my fan leads and things like that. i bought the shrink wrap, just gotta do it.
coejus
157
Removing the molex connectors is easy. You just push the pins back in the correct opening.
