Case Modding NEWBIE...please help!!!
To make a long story short, I want to mod my mid-tower case so that it has a side window on one side, and a case fan on the other. I also want to mount a black light on the window side. How can I best go about doing this? Exactly what tools do I need to do it efficiently, and relatively cheaply? I've got the black light already; I just need the case fans/grills and whatever else I need to do this job...Are there places I can get a kit to do a mod? Thanx in advance!!!
If you got $60, go to Wal-Mart and buy a Variable Speed Dremel Mutli-Pro.
If you decide to get one, remember to get the corded one. The cordless is half as powerful and the battery life sucks.
Home Depot and Wal-Mart both have $60 kits. The Wal-Mart one has more accessories though.
Also, I think it would be better if you put an intake at the bottom front of your case and an exhaust on the top back.
Good luck on your project!
