vietbboibrave
Ok, I'm looking at trying my hand at water cooling this summer, but I don't want a behemoth of a case (full tower).
That said, I'm looking at the Lian Li V1200. My questions are:
1. Would a Black Ice Xtreme 120.1 radiator put in the place of the front 120mm fan be enough cooling power for a CPU and GPU block? In the xtreme systems sticky the guy suggests at least a 120.2 for cpu and gpu but maybe with high CFM fans it would be ok?
2. Otherwise, where would be the best place to try and put a dual 120.2 radiator (e.g. Swiftech mcr220)? Is there enough clearance on the bottom (between the wheels) or would you have to put it on the top towards the front of the case, or is there anyway to put one on the back? Or heatercore inside by the 5.25" bays? I dunno, lol..
3. How hard is it to mod a case? i.e. put in a window on the side and possibly cut holes for the radiator? I haven't researched much about putting a window in there but I believe with a RadGrillz the modification for the radiator wouldn't be too hard.
Thanks for any help guys!
